W204 pre-fl instrument cluster retrofit
Old Mar 28, 2020 | 01:35 PM
henry666's Avatar
Mercedes Benz C280 2009
Finally got E class color instrument cluster,
spent couple hours in coding, then update the firmware that is silver background.
Reset the mileage without using and CAN filter or blocker
All working as is and no fault code.
Old Mar 28, 2020 | 06:01 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Ok wow great job
Is it in Chinese because you chose that setting?
Old Mar 29, 2020 | 12:45 PM
henry666's Avatar
The cluster support Chinese Japanese Korean English German as display language,
So try to make sure that works.
The original cluster only support English and European.
BTW I know Chinese and Japanese.
Old Apr 21, 2020 | 08:53 PM
Trdspec86's Avatar
W204
Hi Henry, noticed that ur using audio 20. How do u set the time n date since there's no setting for it inside the new cluster menu?
I've also fitted a FL cluster n can't adjust the time n date.
Thanks in advance.
Old Apr 25, 2020 | 10:01 PM
Trdspec86's Avatar
W204
Retrofit cluster issues
Any advise?
Anyone with info can share?
Old May 19, 2021 | 11:43 PM
henry666's Avatar
Thanks in advance.
By default time and language settings are hidden and need to set from Audio then it will sync to speedometer cluster automatically.
It is easy to code the cluster to re-enable time and language settings,
change time/date format, 24->12, yyyy/mm/dd, dd/mm/yyyy etc.
For languages, FL cluster already supported most western and asian languages, and support some middle east.
You can code it to display all supported languages, restrict to some western and asian, or no asian.
Old May 29, 2021 | 03:42 PM
MBPT's Avatar
W211, W204, C207, W205
Was the cluster virginized? How did you code it?
Old May 31, 2021 | 01:04 AM
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
must virginize... I did the same
Old Jun 16, 2021 | 04:00 AM
henry666's Avatar
Actually no need to virginize the cluster.
If you have tool can direct read/write the cluster through OBD or CAN bus, only four bytes is needed to 'marry' the cluster to your car,
then if you want to keep the original mileage there is another 64bytes, or you can program the mileage to anything you like if you know the principle (no CAN blocker is needed).
the last thing is coding, code the cluster to match your car's options.
It is easier get coding from original cluster for reference, then match them to the new one.
so no SCN coding is needed.
If that is used cluster, it is better clean up assyst data, of course you can keep it or ignore it.
Old Feb 2, 2022 | 05:32 PM
MBPT's Avatar
do you have any more info on that? I have a cluster ready to install
Old May 9, 2022 | 02:29 AM
Marcil802's Avatar
C300 2010 4matic
What are you coding with?
Old May 22, 2022 | 03:20 PM
Zapan's Avatar
2012 C63
just wondering, i have a facelift 2012 C63 with the yellow beckground gauge cluster, how did you manage to make it the silver one? does the cluster itself need to be changed? is it a update only or is there much more to it?
Old May 25, 2022 | 01:40 AM
Trdspec86's Avatar
W204
Yes, the software can be updated to the newer silver color theme. But u'll need some tools n correct cff file to do the update.
Old May 25, 2022 | 11:22 PM
karlt10's Avatar
Is it possible to get rid of the AMG logos for non-AMG cars?
Old May 11, 2026 | 10:38 PM
leandrolg91's Avatar
How did you make that do you have a tutorial or post to help us on that update?
