Broken dipstick - needs extraction
You might also be able to remove the dipstick tube. I did that on a 2004 Jetta— it just snapped in.
Here it is. Two bolts on the bracket but you’ll have to see how accessible it is.
G’luck!
5
I'm really surprised at how easily it broke. same goes for one of the clips holding the battery cover and who know what other clips I've forgotten about in the engine bay. I think a part of the air intake or the housing around it has a clip missing also.
Not sure where you live, but you're not getting a labor rate that low anywhere in the US. But thanks for telling me what i should have done in a thread where im asking for a specific technical advice. I never knew taking it to the dealership was an option.
G’luck!
5
One of thenfirst things i tried was surgical pliers but there's not enougj to grab.
My thinking is that you remove to tube in order to access the broken dipstick. It will just slip off once the bracket bolts are removed. There’s probably an o-ring around the bottom connection.
Then replace everything and insert the new dipstick.
On the Jetta, the tube was plastic. That’s my main gripe about older VWs, the plastic bits just disintegrate. At least the MB is steel.
Pay attention to the exact location when you remove it to make sure you can find the hole when you reassemble. It appears to go into a plastic or rubber bushing (#22). See below.
The picture is upside down. The seal may also come out of the block or pan with the tube.
5
https://www.harborfreight.com/5-1-2-...amp-99930.html
If that doesn't work then removing the dipstick tube is fairly easy. The pictures above show you how it's mounted and once you remove the intake box you should have just enough room to reach down there.
The actual tube slides into a seal on the engine block. You most likely will not need to replace the seal but the tube should slip in and out very easily unless you have some other problem. The two bolts holding the bracket on will be e-torx and most likely 10mm and if you have a 12-pointed socket you can remove them. They won't be bolted down with much torque so you don't need to worry about stripping them. I've done this on similar bolts in a pinch and didn't strip or ruin the head. This obviously isn't ideal but it avoids buying extra sockets unless you want a set. Anything larger like 12mm or 14mm I wouldn't suggest since the bolt would be held down with greater torque.
https://www.steris.com/healthcare/pr...-micro-forceps
