Groaning sound when reversing and turning.
Old May 11, 2020 | 11:36 PM
cmarilee's Avatar
2012 C300, 2002 C230
About a month ago, my 2012 C300 with 95k miles started shuddering at 50 mph. I thought maybe gas line but took to a local mechanic. He thought needed spark plugs because of mileage and also needed rear brakes per inspection. I am not driving much because of virus, so the next week when I had to drive somewhere, there was groaning sound and shaking from front end while reversing and turning at low speed. Seems okay while driving straight at higher speed. Mechanic took it again and fixed slow leak in front left tire and corrected other air pressure. No difference in groaning/rubbing sound. I basically had not driven since the brake job. Mechanic said that brake job should not have had any effect on front end noise. He is looking at car again today but don’t have confidence. Could brake job have done something? Could he have hit pothole while returning the car to me? I read could be steering wheel or CV joint but don’t want big repair that is not needed. I am far from a Mercedes dealer but thinking I should get towed there as last resort. Any ideas? Thank you.
Old May 12, 2020 | 08:07 PM
rocketman4321's Avatar
2013 C300 Luxury
If you're not driving much, the surface rust on brake rotors can cause a fairly loud scraping when braking until the rust wears off. However, it shouldn't shudder. Sounds more like a tie rod or a ball joint. A brake job shouldn't affect these, and you had the shudder before the brake job. Hard to believe the mechanic didn't check all the front end parts given your shudder, but maybe he missed.
Old May 13, 2020 | 12:29 AM
Just204's Avatar
Mercedes w204 4matic sport
Does it shutter consistently when you turn the steering wheel to a certain spot? Groaning how? High pitch? Does it groan or whine if your not moving and turn the steering wheel?
