help me to diagnose.
Old May 14, 2020 | 01:40 PM
brintrox's Avatar
w204 c200
hello friends,
i have a w204 c200 from 2010 since last year and i have a problem since 1 month the car is very slow and can't go above 3000rpm
i have read my faults can you help me to know what's the problem and how to solve it ?
i have 2 diags 1 before erase and the second is the faultcode that apear after 500m.
i don't know if it change anything but the car is ecu remap at 215hp
thank you all for your help
1st diag : Registered Faults
P2453 Intermittent The input for differential pressure sensor 1 in the diesel particulate filter. 57429
P244A Intermittent Diesel particulate filter differential pressure 69
P244A Intermittent Diesel particulate filter differential pressure 76591
P2454 Intermittent The input for differential pressure sensor 1 in the diesel particulate filter. 69
P061B Intermittent Internal control module torque calculation performance 76591
P200A Intermittent The charge movement flap (cylinder bank 1) has a malfunction. 57429
P2455 Intermittent The input for differential pressure sensor 1 in the diesel particulate filter. 69
P0237 Intermittent Boost pressure sensor 69 P2263 Intermittent Boost pressure regulation, incorrect flow 76591
second diag : Registered Faults
P244A Permanent Diesel particulate filter differential pressure 76591
File Type: pdf
File Type: pdf
Old May 14, 2020 | 09:28 PM
ihaveaquestion's Avatar
2000 C230 Kompressor
Belgium? I may visit a friend there after the pandemic is over.
Sorry, can't help much as we rarely have any diesel in the states.
Old May 14, 2020 | 11:45 PM
Just204's Avatar
Mercedes w204 4matic sport
Diesels have a catalytic converter style filter for the diesel in the exhaust I’m pretty sure. Ever clean it? Go on google and search Diesel particulate filter and read up on it, most of the codes seem to be sourcing from it.
