Where's the rest of the tranny fluid?
So I only got 2-3 liters out of the pan, even dislodging the standpipe and dropping it. Not much in the start/stop pump. Got a solid 3 or 3.5 liters from the torque converter. Call it 5.5 all together, and that might be charitable. I thought it was supposed to be more like ~9 liters total. Where's the rest, or am I good to refill starting with about 6.5 liters and doing the draining procedure?
Correction--just found a little more in the other drain pan. Call it 7.5 liters total--8 at the very most. Close enough?
Thanks!
Thanks!
