Instrument Panel Out- U0155 Code
Old Jun 13, 2020 | 06:30 PM
2012C250BlueTec's Avatar
2012 C250 1.8L Turbo Blue Tec
Any advice, tips or tricks appreciated. Went out to leave today and 2012 C250 started up but without any instrument panel lights. They're ALL OUT and I get a U0155 code. Checked the engine compartment fuse box on 5 & 28. Both are 7.5 and look fine. I also took off the cover on driver's side dash and could not see any fuses. There has been no prior signs or indications of a problem with the dash cluster lights. I did recently leave all my windows cracked a bit and it rained some but did not notice any rain on the dashboard, etc.. Thanks in advance.
Old Jun 14, 2020 | 02:14 PM
Apparently, these MB German engineered cars are self healing. I checked this morning and everything is working fine now. Admin- you can delete this post. Thanks
Old Jun 18, 2020 | 01:59 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
If you did get water inside the car, you might have a CAN communication problem causing the instrument cluster not to get a key on message. You might want to check under the carpets.
