DPF workaoround
Old Jun 17, 2020 | 04:59 AM
sorcer's Avatar
c250 2.2 cdi
DPF workaoround
I'm searching for a way to trick the ecu to sense that there is no soot in DPF and doesn't need to start regeneration.
As I seen the c250 cdi w204 has only 2 sensors on DPF , one differential pressure sensor and one temperature sensor. So, if I can make the differential pressure sensor signal to have a certain value (like 0,01) and the temperature sensor signal have a certain temp reading( like 200 degrees) then the regeneration should not start ever right ?
Can anyone tell me how to find the sensor value that triggers regeneration ? Am I missing something ?
Old Jun 19, 2020 | 02:31 AM
sorcer's Avatar
c250 2.2 cdi
Any ideas on the subject ? nobody tried this before ?
Old Jun 19, 2020 | 06:58 AM
Gazwould's Avatar
S204 C250 CDI Sport
Ummm there's alot wrong here..
If you prevent regens the dpf will block .
Giving a differential pressure sensor too a low reading will make it think it has a leak and go into limp mode .
Old Jun 19, 2020 | 03:06 PM
sorcer's Avatar
c250 2.2 cdi
In normal working condition dpf differntial presure is between -0,01 and 0,02 acording to my readings with delphi ds150 .
Yes blocking regeneration will block dpf , but also can be a workaround if dpf is empty ( no ceramics inside).
Do you know if there is any other sensors that contributes to soot level calculation , or only the differential pressure sensor does the job ?
