SRS front right passenger u014500 code
both sides were flashing but i got one to reset with icarsoft mbII scanner. looked under the passenger seat and found the bracket that holds the plugs is broke. I UNPLUGGED EVERYTHING ON BOTH SIDES AND light pops right back on after a minute or so. i unplugged battery cable for a while and reset, still pops back on. check all fuses with multi-meter got continuity with all. the code reads weight sensor can communicate. i will add pics. any help would be grateful, or to the dealer i will take it. because i see the airbags are nothing to play with. i have tried to sit in the seat and try different pressure points but still nothing.
