Need help with D1S bulb assessment
Old Oct 12, 2020 | 03:07 PM
yober37's Avatar
2012 C300 4-MATIC Sport, 2012 BMW X5 xDrive35d
Hi all
The left headlight’s bulb bi-xenon D1S got burnt on my 2012 C300. The original bulb was Philips brand. I bought exact the same bulb from Amazon. It arrived the next day after order. I’ve checked the label and it looks exact same as my burnt one. I replaced the bulb and to my surprise the new bulb brightness does not match to the one on the right headlight, i.e. the new bulb is more yellowish.
Question: does these type of bulb needs some time to burn in order to become brighter (more white)?
This is the new D1S bulb
This is the burnt D1S bulb
Old Oct 13, 2020 | 12:11 AM
WestonMerc's Avatar
2015 C250 Coupe M271.860
From what I’ve read it can take 50-100 hours to burn in. When I replaced one on my bulbs (it was a phillips D3S) on my Audi it was an exact replacement and the color looked fine to me from the start, but maybe I just got lucky.
Most sources will say replace them both at the same time but I think that’s a waste of money.
Old Oct 13, 2020 | 12:47 PM
aznmode's Avatar
2010 c300
Doesn't seem right. Is it a knock off?
Old Oct 13, 2020 | 12:50 PM
aznmode's Avatar
2010 c300
Doesn't seem right. Is it a knock off? Or what is the light output listed as?
Old Oct 13, 2020 | 01:59 PM
aznmode's Avatar
2010 c300
I bought these aftermarket ones on Amazon and it was whiter than my stock from the start. So I cant imagine a Phillips one not doing the same. Anyhow this one is still going strong almost 3 years later. Just sucks theyre no long available otherwise I'd say for the money just get these.
Old Oct 15, 2020 | 08:32 PM
samaritrey's Avatar
Super Moderator
THE C350
@yober37
that is normal that it won't match as your old bulb has color shifted (al HID bulbs do that as they age ever seen an old Acura with an almost pink light?)
The Philips bulbs tend to go darker blue which many like but in reality they are putting out less lumens and are worse than the new bulb even if they look "cooler".
This is why it is recommend to replace older hid bulbs in pairs so you restore you light output back to new!
On my old w203 when I replaced the original bulbs to new Philips ones I couldn't believe at how much more I could see on the dark country roads. Now if you never leave the city then it may not be worth it to you.
I always buy my bulbs from a place down in Atlanta called The retrofit source as getting genuine bulbs at a decent price is sadly very hard. Way to many fakes on Amazon (got burned a few times even though they came straight from Amazon).
Old Oct 16, 2020 | 10:16 AM
yober37's Avatar
I did check the barcode and QR code and both confirming this bulb is original Philips.
