Battery Replacement to fix ECO START/STOP?
I drive a 2014 Mercedes C300 with about 57K miles on it. Was wondering since the car is nearing on 7 years old and the batteries haven't been replaced, should I look into replacing the batteries to see if whether or not the ECO START/STOP will start working again? Mine hasn't worked in months. Was wondering what are the steps I can go about to fix that issue. Also I noticed the HOLD functionality does not work sometimes too. So I've been reading about it, apparently the Auxiliary Battery is the source of the power for the HOLD and ECO START/STOP is this right approach?
Best,
Vlad
When I had issues with Brake Hold sometimes becoming unavailable it was due to the main vehicle battery. Once I had that swapped it all went back to normal. So I'd start with that first.
When I had the battery swapped I used BMW Roadside Assistance to do it. When done that way they don't charge labor so it was much cheaper than the dealer if you're doing OEM. Also had the added benefit that they changed the battery at my house (was done by a BMW tech).
I am about to replace the aux battery on my 2016 E400 and I looked at he available videos. looks like a straitgforward easy thing but I just want to make sure couple of things. Do I need to disconnect the main battery first or do any other preparations before I start, also, any resets or computer tinkering needed after the new battery is installed? I would appreciate the answers very much !
By the way, my start/stop has never worked since I got the car about 1.5 years ago, but it never bothered me because I'm with those who believe that its benefit is barely noticeable...
Also, probably related to the main battery, but a few months ago my Comand system stopped powering on its own when I start the engine, I have to push the button in the middle of the console, is it because the battery is low and it's trying to save juice, or is it a symptom of some other issue?
It was a pleasant surprise btw to learn that the signal for the clock comes from the GPS/Nav, so for the first time in my life, I don't have to do anything for daylight savings time, at least not in the Mercedes :-)
ENGINE OFF:
UB: 12.1A and IB: -10.6A
ENGINE ON AND IDLING:
UB: ~14.7 to 14.9 A and IB: ~11.0A to ~12.0A
Based on these readings, it seems like the battery is still okay, despite the car being almost 7 years old at this point. Should I just replace the main battery despite it being I guess what to me looks fine?
Also, Is there a way to test the auxiliary battery to see what the readings are and what they are supposed to be? Is there a way to check the charge level on that?
If I go ahead and replace the Auxiliary Battery, where is it located? I opened the trunk and I did see a battery attached.
Should I look into buying this one from FCP EURO:
https://www.fcpeuro.com/products/mer...300-2115410001
Best,
Vlad
A month and a half after giving mine the long overnight charge, I've noticed the ECO re-start is not as smooth as it was. Maybe that means it's fallen back to the 80% range?
Anyway, worth a try if you have a charger and can leave it on the battery for a day.
So that lead me to believe that this issue from the get go might have been with the main battery as some of you guys have pointed out. Perhaps the outgoing main battery was not able to keep a charge or something. I'm not sure how long the Auxiliary Batteries last, but nonetheless, I decided to swap out the main battery today since it was on the list of things I wanted to do with the car anyway. So I called Roadside Assistance, the roadside assistance tech came to AutoZone where I bought the battery and he had assisted me with the battery replacement. The car starts notably much quicker and snappier than before with the older battery. I have still yet to test the Brake HOLD feature haha, but I will test it today and see what happens.
When I drove out of the AutoZone lot with the new battery, the ECO was still yellow; but i'm gonna give it the benefit of the doubt because I didn't drive it much on the new battery, so my assumption is that the new battery has to be charged more. If that still does not work, then maybe the Auxiliary Battery is on its way out as well. The roadside tech who replaced my battery said, if there is no warning light for the Auxiliary battery, then I should not replace it. When I had told the tech who replaced the battery the issue, he advised that the ECO Start/Stop does not work its usually the Auxiliary Battery that should be checked, however that battery looked flawless when I opened it up from the back, so I am gonna give this new battery a good drive and see what happens, and let you all know!
ECO/START STOP & Brake HOLD Working. 😊
When in doubt check the battery! Its working perfectly now. 😉. I personally like the ECO system because I live in the city and it is particularly useful for me. Turns out the battery was not ever replaced since 2014 when the car was shipped, so I think it really outlasted itself. 😊
