W204 2012 C 300 Tire Presure Monitor Inoperative
Old Feb 7, 2021 | 04:24 PM
TPK's Avatar
TPK
Mercedes C300
Hello,
My '12 C300 has a error "Tire Pressure Monitor Inoperative" message on the dash every time I start the car.
Additionally, the warning light stays on.
I've tried to re-set using the buttons on the steering wheel, I used a code reader to clear the fault and the error message returns.
I've replaced the wheel sensors located in the tires and made sure they are working.
I've seen tid-bits of info about a ground wire fix, but nothing specific enough to complete the fix.
Has anyone on here experienced the same issue, and if so, how did you fix it? Can you tell me the location of the TPMS sensor?
Thank you in advance.
Old Apr 29, 2021 | 10:52 AM
BattleScarze's Avatar
GLK350
I am having a similar issue, I have a '14 C300-does anyone know where the sensors are? Or where the module is located?
Old May 4, 2021 | 09:32 AM
TPK's Avatar
TPK
Mercedes C300
Mine is fixed now
Hello,
the module is located in the trunk, below the spare tire. I took mine car to the dealer for the airbag replacement and asked them to diagnose it.... they said they “reset” the module with their computer. It has worked flawlessly ever since.
Old May 4, 2021 | 09:43 AM
GLK350
Originally Posted by TPK
Hello,
Thanks kindly, I appreciate the response I’ll have a look today.
Old May 6, 2021 | 12:25 AM
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
Hello,
make sure you have the right frequency TPMS sensors, some cars is 315 some is 433
