control arm questions
got a 2008 c300. got in a fender bender/side swipe 🙁 and my front passenger control arm (i believe the torque strut?) ball joint link broke off. while inspecting it just decided to do a complete reinstall on this side since the axle boot ripped and the outer tie rod was bent. (technically my fault since i slid on ice and i’ll fix myself)
noticing the control arm bushings are a bit different as well as the suspension bolts i bought. can anyone chime in on if using the new ones are okay or if i need to find oem...thanks
also having a hell of a time getting the control arm back in the subframe sleeve area. any tips on that?
new on left, orig on right
new on left w flutes, orig on right...bent smh from accident
If you have new arm and connected up the ball joint first then if the bush bolt hole does not align then you have other issues.
