View Poll Results: change ecu?
no
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
0
0%
yes
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
change coil
![](https://mbworld.org/forums/images/polls/bar4-l.gif)
![](https://mbworld.org/forums/images/polls/bar4.gif)
![](https://mbworld.org/forums/images/polls/bar4-r.gif)
0
0%
flash ecu
![](https://mbworld.org/forums/images/polls/bar5-l.gif)
![](https://mbworld.org/forums/images/polls/bar5.gif)
![](https://mbworld.org/forums/images/polls/bar5-r.gif)
0
0%
Voters: 0. You may not vote on this poll
C250 misfire
W204 c250 2011 4 matic
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
hello
my c250 4 Matic 2011 got the following codes P0353 P0356 P0306
that means that the circuit is open for the coil #3-6. at first i did swap the coil to if fhe problem will move to the others cylindres. nothing changed... i did change the spark plugs.. nothing changed still got problem with coil #3-6. i did check all the wiring everything seems fine... i dont know what else do?? change ecu ??
