Side marker error
Old Apr 17, 2021 | 02:36 AM
Kimberly Shum's Avatar
2010 c350 4matic
Side marker error
Replaced my orange looking side marker housing to chrome and clear housing. Popped in just fine. Switched the original orange looking bulbs to none error canbus LED bulbs. Right side works and functions fine. Left side blinks three time and stops when I turn my ignition key to position 2. My dash then tells me to check front left side marker lamp. I swapped the LED bulb as well just to see if it’s a bad bulb - error still popped up. I didn’t cycle my car, How do I do so? Also, might I have pulled on the cord? How do I fix, how do I solve? I really don’t want to bring this little thing into a shop.
This is my centre dash
This is my left side (driver side)
This is my fully functional right side. (Passenger side)
Old Apr 17, 2021 | 07:46 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
Are you getting 12V at the lt. side bulb socket when ON ?
Old Apr 17, 2021 | 11:16 AM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
You need a scanner and clear the codes in that specific module. I remember going through this and once the error message is triggered, you have to go in the module and clear the code to get 12v back to the bulb. It may reset on its own if you let it be or maybe disconnect the battery but its easiest with a scan tool like ICarsoft
Old Apr 17, 2021 | 01:08 PM
2010 c350 4matic
what? How do I do this? Do I need a special tool? I’m not a mechanic. 😲 this would be my first car that I slightly mod/vip
Old Apr 17, 2021 | 01:10 PM
2010 c350 4matic
wow. How do I do that? Does the icarsoft get the 12v back into the socket?
Old Apr 17, 2021 | 01:46 PM
Amazon Amazon
If you plan on keeping the car, I strongly suggest you invest in an Icarsoftr scanner. It wil be able to read and reset codes for all 35 modules on board. Mechanics typically charge 60-80$ just to plug in their scan tools so it will pay for itself real fast.
Old Apr 17, 2021 | 05:01 PM
2010 c350 4matic
https://www.amazon.com/iCarsoft-Vehi...681472&sr=8-10
I do plan on keeping the car. 😁 where do I find the modules? 😲
