Help! 2011 c350 Everything stopped working (ac, power windows, radio, signal, etc)
Old May 19, 2021 | 11:55 PM
Palmtown's Avatar
2011 c 350
Hi guys. While driving, the ac turned off, the power windows wouldnt work, radio turned off, brake lights wont light up when braking, no signals, no power locks, trunk does not open with button, and the radiator fan blows on full speed, and the all dash alerts turned on.
I assumed it was the fuse box so I bought one from ebay, installed, no luck. And worse, the key does not work anymore.
I assume it’s an expensive fix at the dealership.
Any help is appreciated because I used the search and it only gave results to a few on the symptoms and not that Pertained to what I went through.
thanks. I am in los angeles, if you can recommend a spot to have it towed to and repaired for wayyyy less than the dealer. Or fixes I can do at home. Thanks.
Old May 20, 2021 | 12:46 PM
Palmtown's Avatar
2011 c 350
Also, want to add, I think putting in another fuse box bricked my car
