W204 2010: the battery is drained because not charged while the vehicle is moving
My car:C-class W204 2010,it has phenomenon: every 3-4 days the battery is weak, can't start the car.
I have replaced new battery, generator IC, battery sensor but not solved the problem.
I checked and noticed: when the car starts in place, UB > 13V, the battery is charged normally. If moving the car, UB drops to 12.5-12.7V, IB is negative, battery is not charged (see picture)
Has anyone encountered this situation? help me!
When parking:
When moving:
When parking:
When moving:
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Hi,
I have had really good results with Ctek battery chargers mine is 5 amp unit, I think first you need to fully charge your battery with Ctek or modern charger to make sure the battery is fully charged and topped off at around 13.8-14v.
Then start and see what the dash display is saying once engine running, with above idle should see 13.8 or above up to 14.5V.
I may be that you have had the battery go flat and has not quite fully recovered with your charger then short drives are not recharging it sufficiently.
Is it original 2010 battery?
