2013 Mercedes C300 Bank 2 O2 sensors help!
Old Jun 1, 2021 | 12:32 PM
Michael101's Avatar
2013 Mercedes Benz C300 4MATIC Sport
Hi I’m having trouble with Bank 2 Sensor 1 and Bank 2 Sensor 2 codes. I used my scan tool and all of the values look good besides ECT which is red. I’m assuming that’s my engine coolant temperature sensor. The car does not overheat or stutter. No weird sounds. The check engine light comes on every 2 days for o2 sensor stuck or biased. I’ll post the pictures of the codes. Would the ECT sensor trip the O2 sensor codes? Need help thanks!
Old Jun 1, 2021 | 12:34 PM
Michael101's Avatar
Also, where would the ECT sensor be located on the 3.5l V6 w204 from 13-14
Old Jun 1, 2021 | 06:35 PM
Michael101's Avatar
Anyone?
Old Jun 2, 2021 | 11:24 AM
Michael101's Avatar
Bump
Old Jun 2, 2021 | 10:52 PM
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
The Temp is normal,
the other codes is one or two things, either you have a vacuum leak or your cats is going...
to be honest I hope you have a vacuum leak because cats aint cheap
Old Jun 2, 2021 | 10:58 PM
Michael101's Avatar
Oh man, it’s only 65k miles. I think previous owner used cheap gas. I put some 91% alcohol in the tank. Hopefully that helps a little.
