Engine sludge
Old Jun 19, 2021 | 05:51 AM
delija's Avatar
CLK230 K, Avantguard
Exclamation Engine sludge
Check what i found. How is this possible...mother of god!
I plan to chip out bits and vacuum as i go.
Any suggestions how to clean this, with diesel maybe?
Old Jun 19, 2021 | 08:03 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Wow
what model is this?
Old Jun 19, 2021 | 08:44 AM
delija's Avatar
Originally Posted by Adi-Benz
Wow
what model is this?
C250, year 2010 with 200,000km.
Old Jun 19, 2021 | 11:55 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
do you follow the recommended oil change intervals of your car? That is really bad!
Old Jun 20, 2021 | 04:02 AM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Please tell us what time & milage between servicing, what oil you are using and how long have you owned your car , just want to make sure I don't end up with the same problem.
On a serious side, degreaser scrape off what you can and vac it up use a stiff brush and some degreaser type fluid to wash everything else mop up what you can, remove the sump plug and let what flows in the top of the engine flow out the sump plug and keep cleaning until spotless.
Let it drain overnight, install sump bung full with diesel oil warm up then quick spin around the block.
Change oil and filter refill with diesel oil, drive until oil changes colour then change oil and filter again.
Old Jun 20, 2021 | 08:36 PM
Adi-Benz's Avatar
It reminds me of this thread, so likely no oil changes:
https://mbworld.org/forums/c-class-w...50k-miles.html
