Door Panel Clips
Old Jun 27, 2021 | 12:59 PM
Stigman's Avatar
2010 C300 Sport
Question Door Panel Clips
I'm currently replacing the door handle on my 2010 C300 Sport on the driver side door.
I've finally managed to get the panel off but for the life of me I can't find out want the following clip is called or find a part number for it.
I promise I've looked at at least 1 million posts and images about clips but nothing that looks like the following.
Please end my misery by telling me what this is.
Have a good one.
Old Jun 27, 2021 | 03:06 PM
alecmascot's Avatar
W204 C220CDI 2011
You should be able to find it in the IPC :
https://7zap.com/en/catalog/cars/Mercedes/brand/29/0
Old Jun 28, 2021 | 10:17 AM
Stigman's Avatar
2010 C300 Sport
Thanks alecmascot
Unfortunately, once I entered the car Series I didn't really understand what it was asking me when I needed to select the "Modifications".
Whilst I was browsing that catalog however I was served some ads, one included a retainer clip (which I had come across before). I clicked on it and although it didn't look exactly like what I was after I then did a search using the part number it provided.
And voila, a post from this very forum matched the part number and the user had even provided a picture of the item and thus I now know what the part is.
How To: Interior door handle illumination - MBWorld.org Forums from 2017!
Even knowing the name and part number of this item this forum is literally the only place where a pic exists.
Awesome.
Have a good one.
Old Jul 4, 2021 | 08:02 AM
Stigman's Avatar
2010 C300 Sport
So I received my clips in the post and I'm happy to report they are the correct ones. When checking if they fit my vehicle it says that they don't fit!
When looking around for somewhere to buy them from pretty much every place wanted $20+ just to deliver 1!
I got them from the following place, delivery was around $11, which is still daylight robbery.
2010-2015 Mercedes-Benz Door Trim Panel Retainer Clip 000-991-79-40 | Helms Bros Mercedes Parts
Have a good one.
Old Jul 4, 2021 | 04:49 PM
chassis's Avatar
2017 GLE350 4MATIC
Thanks for posting this. I had a heck of a time getting that retainer re-installed in my W166 after I replaced a cracked wood trim panel. Removing it is easy - use needle nose pliers and pull out the key in the middle. To unlatch and remove the outer retainer, the key needs to be reversed and reinserted, then the entire retainer comes out and you can remove the door panel.
Re-removing the key once it has been used in the removal configuration was a pain. There are locking nubs molded into the key and I wasn't able to easily figure out how to release this. Eventually the key came out but I'm not sure if I could repeat this feat again.
Thanks again.
Old Apr 18, 2022 | 11:20 AM
Eurojet's Avatar
2011 C63 (Summer toy) 2018 C43, 2023 Audi SQ5 ( wifes car but sometimes allowed to drive it)
I know this is a old post but all i can say is thank you
been looking for this part
