Ac cooling intermittent
i have 2012 mercedes. My ac works only in morning. After about 30 minutes it blows warm air
i
changed condenser, compressor selenoid, and then a new compressor and still have same issue.
i have no clogs in system or metal shavings.
Is there a possibility that the auto repair put inappropriate compressor oil that is making the issue, or the ac service machine is filling my system with rubbish refrigerant.
thank you in advance
Hook some gauges up and check pressures with ac on. If the low side stays up around 60 or higher chances are the liner on the suction line is separating.
Can remove line and bore scope to make sure.
Here are my readings
i do not have a leak at all.
this is after extracting freon performing vacuum and then adding back refrigerant.
Please report back after trying.
