Multiple problems
I GOT IT FIXED FINALLY ! MY FINDING WAS INSIDE MY PRE FUSE BOX LOCATED IN FRONT OF THE BATTERY. ALL THE ABOVE FAULT WAS CAUSE BY A BLOWN 80A FUSE INSIDE MY PRE FUSE BOX. IS TRICKY TO GET OUT AND AFTER OPENING IT I CHECK FOR CONTINUITY AND FOUND THE 80A FUSE WAS BLOWN. INSIDE THE PRE FUSE BOX YOU WILL SEE THE SQUID THAT WILL SHUT DOWN YOUR VEHICLE AFTER AN AIR BAG DEPLOYMENT , ALSO A 100A AND 150A INSIDE PLUS SMALL FUSE. I DID RESEARCH WITH THE POST FROM THIS SITE, ALSO ALL DATA SITE FOR SCHEMATICS AND YOU TUBE HOW TO REMOVE THE UNIT. ONCE I CHANGED THE FUSED THAT COST $8 AT NAPA AUTO PARTS WHO HAD IT ON HAND. IF I ORDER IT ONLINE IT WOULD TAKEN A FEW DAYS THAT I DID'T HAVE. ALL MESSAGE FROM DASH WHERE GONE EXCEPT THE SRS THAT I GOT A FRIEND TO ERASED IT. ALSO I ERASED THE MEMORY FOR ALL OTHER FAULTS STORE IN THE CAR COMPUTER. IMPORTANT IF CHANGING THIS BOX THE BATTERY IS THE FIRST THING YOU REMOVE AND THE LAST THING YOU INSTALLED TO AVOID SHOCKS OR AIR BAG FUSE BEEN BLOWN.
