c30 electrical issue
Sounds exactly like the alternator is not charging for some reason.
First you need to fully charge the battery then you need to test the alternator for charging.
Usually this is done by comparing the non running battery voltage ie 12.8V with the running voltage 13.8- 14.5v which would indicate all is well.
With yours I suspect you will find like 12.8V non running and when running 12.5 or something like this, then the alternator would most likely need replacing.
There is a menu on the dash which can display battery voltage, I am not familiar of what menu is required to display this.
Either way fully recharge the battery first that will point you in the right direction.
