Big brake kit (OEM parts)
Old Jan 13, 2022 | 04:10 PM
Mb4li5's Avatar
Mercedes c250 4matic
So as you all know the 204 in Canada started with the c250. It had horrible brakes only single piston and 295mm rotors. Best upgrade that we can do and still use factory 17 inch rims is a brake swap from a w212 e550
Old Jan 13, 2022 | 04:11 PM
Mb4li5's Avatar
Btw new rotors are 344mm and you will also need to get 10mm wheel spacers to clear the Brembo calipers.
Parts used 344mm rotors from 2010 e550 4matic
Calipers are from a 2011 e550 4matic
