0954 P2422 Evap issue
Charcoal canister close valve - without power, I could blow through the orig valve verifying that it is normally open. After applying +12V, the orig valve closed successfully. However, with pressure blowing against the diaphragm, as voltage is removed, the plunger did not have enough force to re-open the valve. Aha! Replaced it with a new OEM MB part and tested again outside the car. After applying +12V, the valve closes, and when voltage is removed, the plunger is strong enough to re-open even when I'm blowing into the valve. Feels like a major win, but 0954 code persists after replacement.
Charcoal canister - Disconnected evap line connection from engine bay, blew into charcoal canister and noted no blockage.
Evap lines - Disconnected evap line downstream of engine bay purge valve. Capped off same line prior to charcoal canister connection. Drew a vacuum from the engine bay back to the right wheel well and confirmed no leaks between purge valve and canister.
Gas cap - gas cap appears sealed, applied a very small amount of lubricant to rubber seal just to be safe. No issues with the gas pump clicking off during refueling.
Purge valve - Car had an evap code (unknown) a while back and this part was replaced with a URO part. As part of this recent diagnosis, I replaced it again with new OEM MB part. When using a hand vacuum pump on the intake manifold side of the purge valve, I could not establish vacuum with the brand new OEM MB part... is that normal? Seems like without voltage, the valve should be shut and a deep vacuum could be drawn against the intake manifold side. Both new and old valves acted the same, however.
Further diagnoses - Scan tool can command purge valve on and it clicks/pulses audibly with PWM signal. Scan tool can also command canister close valve to open/close. I pushed a bit of compressed air from the engine bay evap purge line downstream into the canister/fuel tank and watched pressure build on the scan tool (fuel tank pressure sensor?). This pressure immediately dissipated when commanding the canister close valve to open.
After a short drive, it's got 0954 / P2422 pending again, and I did notice at one point the OB2 I/M readiness showed a failed purge flow monitor test: $7E8 - MID $3D TID 8C. Valid range for this value is -7373 to +32767 and the car registered -11041.
A few days ago the scan tool registered -17 hPA as the pressure in the tank with the canister close valve open. Today, it registered only -3 hPa in the same condition. Converting to PSI, these are really small values and could just be temperature fluctuations? Is it possible the fuel tank pressure sensor is failing? After a lot of thinking -- is this pressure sensor the only method the PCM has to know if the canister close valve is open/shut?
Any ideas or help is greatly appreciated.
