unknown module
looks to be a battery powered retrieve, may have been required from a previous insurance company or maybe even an ex company fleet tracker
it’ll either have power feeds going to it, or two earths and a VHF antenna,
looking at it, if it’s all black at both ends with just cables exiting out of one end, it’s 100% a battery powered retrieve ( I fit them for a living )
the two solid black cables are earth cables (joining them together activates the internal battery) and the white black cable is the VHF antenna, lift it up there will be a white sticker underneath and there should be a 7 digit serial number
Since I am getting a NO communication with the fuel control module message and since this module is very close to the fuel control module, I came a conclusion that the loose wire has to do something with the fuel module.
Thanks for the info you provided
where can I get this 3 fused fuses?
which one has direct power to all the airbags? all the airbags have and open circuit
what is the name of this part and can I get online and replace it
