C250 W204R transmission shaking
Old Feb 23, 2022 | 04:56 PM
Henry_jenks_'s Avatar
2013 MB C250, 2009 MB SL550, 2018 BMW X3 X30i
Hello I was wondering if anyone was having issues with their C250s transmissions mine a 2013 kind of lightly shakes and vibrates the car getting worse with higher rpm in a certain gear 3rd I think but is fine in every other gear. if anyone knows what is causing this please respond
Old Feb 28, 2022 | 08:48 AM
chabbs93's Avatar
c250 W204
transmission and engine mounts. My tranny mount was enough to make the car shake pretty bad. They pry all need changed if your around 100k miles
Old Feb 28, 2022 | 11:42 AM
That’s probably it since I’m at 120,801 miles how much did It cost because that seems expensive
Old Feb 28, 2022 | 11:58 AM
chabbs93's Avatar
c250 W204
its been a few years but I think 500-700$ To have them all done I think on the 700$ end. I would replace all of them. At least have them all inspected. If they are the suspect you won’t feel and vibration when the car is coasting or idling.
There are tests you can do for the engine mounts on YouTube by giving it gas while in drive with the foot on the brake you will see the engine move excessively.
These cars are made to be comfortable so the rubber doesn’t have a lot of longevity.
