2012 C250 - No acceleration/power
Old Feb 28, 2022 | 07:38 PM
LE5196's Avatar
2012 C250
I recently purchased a 2012 C250 that will be given to my grandson and several weeks ago the dreaded electronic steering lock gremlin hit. I replaced the ESL with an emulator and the car ran perfectly for a few days, but then one morning as I was going to use the car to run some errands, it started as usual but when I stepped on the accelerator...nothing. The car will only go about 5 miles an hour regardless of how hard the pedal is pushed. I'm assuming that it's in limp mode but I didn't get a check engine light for about 5 minutes and after shutting it off and restarting it, no more check engine light. I scanned for codes and there were none. My first thought was that it's the high pressure fuel pump so I ordered one and scheduled to have it replaced at an independent shop. I also decided to replace the accelerator pedal but that did nothing. So now the car is in the shop and I got a call today saying that there are no codes and the fuel pressure is fine. They're continuing to diagnose the problem but I thought I'd reach out to the forum to see if anyone has an idea of what might be going on. Any suggestions?
Old Mar 1, 2022 | 03:32 AM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Hi
Just wondering if you have presses the speed limiter function of the cruse control, button is on the end of the cruise stalk?
Old Mar 1, 2022 | 10:13 AM
LE5196's Avatar
2012 C250
Originally Posted by NZ-Merc
Hi
I'll check this, but if it's a speed limiter, it limits the speed to about 3 MPH at full throttle!
Old Mar 1, 2022 | 12:24 PM
NZ-Merc's Avatar
It depends on how fast the vehicle was going when button pressed, when it happed to my wife she was turning out of our drive pressed button instead of the indicator stalk.
Old Mar 1, 2022 | 01:19 PM
LE5196's Avatar
2012 C250
It started about 3 days after I replaced the electronic steering lock. The car starts and idles perfectly, but when I press on the accelerator, nothing happens. The car just creeps along.
Old Mar 2, 2022 | 09:50 AM
AAIIIC's Avatar
2014 C250 Luxury
I'm assuming that such a limiter is reset when you cycle the ignition, just like any other cruise control setting, so that doesn't seem like it could be the issue here.
Old Mar 2, 2022 | 10:19 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Hi
My 2013 C250 doesn’t have a button on the end of the cruise control stalk.
Old Mar 3, 2022 | 12:15 AM
NZ-Merc's Avatar
Yes I do believe what you are saying is correct, I cannot test to confirm at the moment.
Old Mar 3, 2022 | 12:28 AM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
On my 2013 C250 if you have the cruise control set to a specific speed then cycle the ignition (for example, stop for gas), if you then select cruise control once the car is moving again it will select the previously set speed. One other observation, the cruise control will not set below 25 mph.
Old Mar 3, 2022 | 08:58 AM
alynch's Avatar
My mistake. It's my wife's vehicle that remembers the previous cruise control speed. The cruise speed is reset when the iginition is cycled. Also, the minimum cruise control speed is 20 mph.
Old Mar 3, 2022 | 04:43 PM
Odd Piggy's Avatar
We’ve gotten pretty far away from your original question. Is there any resolution on this issue?
Old Mar 30, 2022 | 11:08 PM
LE5196's Avatar
2012 C250
I just posted a new thread on this. The dealership said it's a problem with the engine control module. It's being replaced tomorrow...fingers crossed!.
