Will a 2013 C300 4 Matic differential fit on a 2008 C350?
Old Mar 19, 2022 | 09:04 AM
MELMASSRY's Avatar
2013 Mercedes Benz C300
Hello everyone,
Ive been helping my brother locate and replace his rotted through rear subframe. Luckily, i found a very good used one that was pulled as a unit(everything still attached including differential and suspension components) off of a 2013 C300 4 matic sport. I confirmed the part numbers matched for the subframe however I am having trouble finding any technical data for the differentials to see if i have to swap them out. Hoping not to so its a clean easy swap. I can’t find the final drive axle ratio for either although i did find the Gear ratios and they match up. So my question is, are they compatible?
My brothers car: WDDGF56X58R032521
Donor car: Wddgf8abodr282157
Thank you!
Old Mar 19, 2022 | 10:24 AM
chassis's Avatar
2017 GLE350 4MATIC
Bad VIN on the donor car.
Old Mar 19, 2022 | 11:04 AM
MELMASSRY's Avatar
My apologies, correct vin:
WDDGF8AB0DR282157
Old Mar 19, 2022 | 01:03 PM
chassis's Avatar
2017 GLE350 4MATIC
Doubtful. Donor car has M276/7G and your brother's car has M272/7G. Gear ratio, propshaft and other parts may not be 100% compatible.
One car is 4MATIC, the other appears to be RWD.
Old Mar 20, 2022 | 01:26 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Donor car: 204-350-05-14-80, 1:2.87 ratio, $1670 list price
Other car: 204-350-02-14-80, 1:2.82 ratio, $3675 list price
Whether it physically fits may require visual inspection.
Whether it survives in service is questionable.
Old Mar 20, 2022 | 09:31 AM
chassis's Avatar
2017 GLE350 4MATIC
Your brother's car is RWD, the donor car is 4MATIC.
Speedometer will be off on your brother's car because of the different gear ratio. Acceleration will be a bit quicker, top speed will be reduced. Shift points may be wonky.
Summary: don't do it, even if it fits.
