New engine control module needed
Old Mar 30, 2022 | 10:35 PM
LE5196's Avatar
2012 C250
My 2012 C250 died on me several weeks ago and the symptoms indicated that the HPFP had died. It started fine but went into limp mode and wouldn't go faster than about 3MPH. I took it to an independent shop and although there were no codes, they also believed it was the HPFP. They replaced the HPFP and after doing so, the car remained in limp mode. After looking at it further, they decided that they couldn't determine the cause of the failure so they recommended taking it to a Mercedes dealership. Fortunately there's a Mercedes dealership located about 10 minutes from the independent shop, so I had AAA tow it there for me. The service manager called me today and said they were also unable to find any codes but while diagnosing the car, the tech said that the throttle body was not responding to signals from the engine control module and they suspect that the engine control module is bad. They said that it looks like a tune had been coded into the module, causing it to fail. They're going to install a new module tomorrow to see if that resolves the problem. What a pain in the butt! Has anyone else gone through this?
The good news is that the independent shop didn't charge me for the HPFP!
