C250 1.8t intake filter
Old May 20, 2022 | 03:13 AM
Nabierkanizer's Avatar
2012 mercedes benz c250 1.8t
Greetings from Southern California. I have a 2012 c250 unfortunately I chose to go for looks other than performance first with the 12.2 monitor, usr lights, grill turbo exhaust pipes, down pipe, and turbo pipe, lastly I went with the tornado tuning intake filter, which as I'm sure you know came with the shroud on top to keep it clean, I tried the burger intake but that was a huge mistake. I haven't chosen a mod just yet, living in California and dealing with emissions if I were to do something dramatic would simply be to much of a pain in my tail quite frankly so my intention is to keep it simple. I think first a pedal commander because of emissions I won't be going with an ecu mod, although she still is a looker she is a 2012 and I want to keep her reliable I put 120 miles a day on the poor thing. So pedal commander and perhaps the burger tune, does anyone have any experience or thoughts regarding this matter? Has anyone Installed a turbo delete and how did that go? Any reliable obd tunes that are some what affordable? So finally is there a better Intake peice other than what I currently have (tornado intake?) A good mode for around $300, and perhaps an obd tune for around $300? Any and all feedback would greatly be appreciated, thank you very much...
Old May 26, 2022 | 05:31 PM
Gazwould's Avatar
S204 C250 CDI Sport
Old Jun 2, 2022 | 03:06 PM
AAIIIC's Avatar
2014 C250 Luxury
Old Jun 2, 2022 | 03:24 PM
Gazwould's Avatar
S204 C250 CDI Sport
I can't see one advantage with the pedal commander ?
OK maybe one....
Old Jun 2, 2022 | 03:41 PM
AAIIIC's Avatar
2014 C250 Luxury
Originally Posted by Nabierkanizer
Greetings from Southern California. I have a 2012 c250 unfortunately I chose to go for looks other than performance first with the 12.2 monitor, usr lights, grill turbo exhaust pipes, down pipe, and turbo pipe...
What are "grill turbo exhaust pipes"? Which down pipe did you go with? And what do you mean by "turbo pipe"?
What was the problem with the Burger intake? Obviously it doesn't have the cover/shroud that the Tornado Tuning one does, but it seems like one could pretty easily bend a shield to accomplish the same effect.
Has anyone Installed a turbo [silencer?] delete and how did that go? Any reliable obd tunes that are some what affordable? So finally is there a better Intake peice other than what I currently have (tornado intake?)
I've seen pretty much zero discussion of C250 performance parts here, including the turbo silencer delete. It's hard to say if there's anything better than the Tornado Tuning intake you've got, since nobody has ever posted any before/after results (dyno or 1/4-mi) for any of the intakes. I do like that the Tornado one has that cover, but as I said, I think you could pretty easily make one to go along with the Burger intake. The ModalWorks one is a completely different design, and is also 2-3x more expensive, so it would be interesting to see a comparison of the two different styles.
Old May 22, 2025 | 07:00 PM
Grinez's Avatar
2010 w204 300C
if you're going to get a "pedal commander" mind as well get a throttle controller from aliexpress for $30 instead of $200 pedal commander or whatever other booster they're showing here, I had mine for 3-4 yr without issues, it even removes the lag input
search "Throttle response controller 9 drive" on aliexpress
