C300 no power to blower motor
I have a 2010 c300, about two weeks ago the blower motor started working on and off. After a few days it just did not want to turn on. I replaced the Blower fan and it still did not work, so I then replaced the resistor and still no luck. I went on to replace the climate control and no luck. I ordered a new resistor and tried another blower fan and that did not fix it. It seems like there is no power going to the fan at all. There does not seem to be a fuse for the blower motor, only the A/C “fuse” 12. Either way I swapped all relays and checked all fuses to make sure nothing is wrong. I also scanned with obd and no issues. The compressor works as I can feel a little bit of cold air when speeding and the pipes feel cold. Anyone got an idea?
