w204 rear subframe tips?
My 2013 c300 sport 4matic has a rotted out rear subframe
i remember reading that a w212 rear subframe will also fit on w204's is this true?
also is there any difference between 4wd and 2wd subframes for the rear?
additionally are there any trick/tips i can use to help the changing process go more smooth? im already aware of putting a piece of wood under the diff when tightening the suspension bolts
Best regards!
Both Sunderland and Newcastle are pleasant to deal with.
Best of luck
