W204 C300 35 offset rims?
Recently purchased set of rims/tires that are are 35 offset all around, but it’s rubbing in the back. Tried searching to see if it’s possible to make it work with a different set of tires but seeing a lot of mixed reviews…
225/40R18
255/35R18
Anyone know if I can make this work somehow? Maybe switch the back the tires? All suggestions welcomed. Thank you!
EDIT: If you’re on this thread don’t do it. Back tires rubbed a lot, ended up selling the set.
Let me mention that I don't think the 215/45 R 18 is a viable option. The appearance would probably be terrible, and handling with the wider tires in front may be so bad that it would be unsafe.
