M271 Cam Chain Tensioner (2013 C250)
Old Aug 18, 2022 | 07:04 PM
jpeter6981's Avatar
2014 SL550, 2014 GL350, 2002 CLK430 Cabriolet
Hello.
Has as anyone changed out the chain tensioner on the M271? Looking at the WIS, it calls for a number of extra steps including locking one camshaft? I've changed at least 10 tensioners on M112, M113, M104, etc. engines, but never have I had to do anything that involved. Any insights?
Thank you.
Old Aug 19, 2022 | 12:44 PM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
Originally Posted by jpeter6981
Hello.
Thank you.
You have to rotate the engine counter to the normal rotation to release the tensioner piston. As the chain is still "slack" prior to the piston extending, it's possible the chain can skip unless the intake camshaft is held in position. You just have to remove the intake camshaft solenoid and use the special T100 Torx socket to hold the camshaft while counter-rotating the crankshaft to release the tensioner piston.
Old Aug 19, 2022 | 04:46 PM
jpeter6981's Avatar
Thank you for the response. That make sense. Jeff
Old Aug 21, 2022 | 01:23 PM
jpeter6981's Avatar
Getting prepared to do the replacement. Just wanted to confirm that, as far as the intake camshaft is concerned, is that it just be held firmly in place while counter rotating the crankshaft? (I have the MB T100 Torx).
Thanks again. Jeff
Old Aug 21, 2022 | 01:49 PM
alynch's Avatar
Thanks again. Jeff
Yes, just hold the camshaft with the MB T100 Torx and slowly counter-rotate the crankshaft. You'll hear a click which is the piston releasing then, when you release the pressure on the crankshaft, you will hear the ratcheting of the extending piston.
Old Aug 21, 2022 | 05:09 PM
jpeter6981's Avatar
Awesome. Thank you again.
