Door Lock Switch button replacement
Old Aug 30, 2022 | 01:52 PM
ClS89's Avatar
W204 Mercedes C300 Sport
Question Door Lock Switch button replacement
Hi there,
I have a 2011 Mercedes C300 Sport (W204).
The button on the lock door switch are all scratched and the black painting is going away. The switch is working fine, the buttons just don't look good. I bought some button replacement but I cannot find any instructions anywhere on how to replace the buttons without to disassemble the switch. Does anyone have some tips?
Thanks.
Old Aug 30, 2022 | 09:48 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Old Aug 31, 2022 | 09:18 AM
ClS89's Avatar
Thank you very much for the quick response.
That is exactly the video I was looking for but couldn't find. It took no time to replace the buttons. All looks good now.
Thanks again!
Old Sep 5, 2022 | 10:34 AM
StraightWisdom's Avatar
2010 C300
damn.. making it look easy..
One of my door lock buttons started to peel, when I accidentally laid some vinyl wrap on it when I was wrapping the trim it peeled one button.
Also my window button is peeling... I bought replacements and I tried to pop out one button and it just would go and ended up messing up the surroundings.
Been kind of apprehensive about doing it again. I also used a tiny flathead to try to prey it and it was a no go...
The peeling buttons is certain an annoyance I want to get rid of. probably got watch this video a bunch of times to sike myself up to replacing them.
Old Sep 5, 2022 | 09:28 PM
gamma300C's Avatar
2009 MB C300 Sport 4matic
I would take a piece of small diameter rubber hose, like for windshield washers, and slip it over my small flat head screwdriver with small piece cut out on lower half side to expose the flat tip metal.. A little soap on the rubber side tip for ease of access...don't soap up the entire length or hose will slide up.
