Electrician needed
Old Sep 22, 2022 | 03:01 PM
Marktee's Avatar
2012 C250 Turbo M271 EVO, 08 X3, 08 328i
Electrician needed
The distributor block in the image below belongs to the passenger footwell of 2012 c250 turbo. The block is rusted from water damage. There are only two wires as in the image and my question is, Are the two wires connected and can I eliminate the distributor by cutting the two wires and connect them directly since Iam
not going to add any devices to the block.
Old Sep 23, 2022 | 12:33 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
They don’t look connected. But that’s a power distribution bloc, so it doesn’t look like it does anything without more connections. Maybe someone has a wiring diagram.
It’s a $10-$15 part. Maybe replace it to be on the safe side?
Old Sep 24, 2022 | 11:23 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
It is a canbus distribution block. I wouldn’t get rid of it. Perhaps, just replace the block. I am surprised that there are no devices plugged into it. Mine has a few items plugged into it
Old Sep 30, 2022 | 07:35 PM
Marktee's Avatar
Do you think this is the problem with the Turbo?
Do you think this would through a code and check engine light?
Do you think this is causing the turbo to roar and moan when I get my foot off the gas pedal?
I bought an after market blow off valve for replacement in the image below, Do you think it will fix the issue. I have not receive it yet
Old Apr 3, 2024 | 05:40 PM
ChristopherGibb's Avatar
BMW
From the image you've shared, it looks like the distributor block in your car's passenger footwell has been damaged by water, causing rust.
Old Apr 8, 2024 | 11:25 AM
BMW
If you're thinking about bypassing the distributor block by cutting and connecting the two wires directly, it might work if you're not planning to add any new devices. However, I'd advise caution and recommend consulting with a professional electrician first to ensure it's a safe and effective solution for your specific situation.
In my experience, when I needed electrical work done, I reached out to PSC Electrical, and they were a great help. They might be able to offer some advice or assistance with your issue.
Old Apr 8, 2024 | 01:41 PM
Odd Piggy's Avatar
@Marktee hasn’t been around for about 11 months. Maybe he gave up on resurrection of the W204 submarine.
