Fault m55 intake port shutoff actuator and limp mode
Old Sep 24, 2022 | 10:47 AM
eacaee's Avatar
W204 C220 OM651
Question Fault m55 intake port shutoff actuator and limp mode
Hello all!
An owner of 2011 Mercedes W204 C220 OM651 engine.
Mercedes dealer replaced my rear axle due to corrosion, and they logged the 'Fault m55 intake port shutoff actuator' fault.
Car has also started to go into occasional limp mode, which disappears after turning the engine on and off.
Is the actuator motor faulty and needs to be replaced? Can this be simply switched off using software? Or the fault code is too vague and this has to be diagnosed with STAR?
I would be very grateful for any advice to point me at the right direction.
Old Sep 25, 2022 | 03:15 PM
eacaee's Avatar
W204 C220 OM651
Originally Posted by eacaee;[url=tel:8640378
8640378[/url]]Hello all!
I’ve done a little bit of research and concluded that the intake manifold is just below the oil cooler, which has a small leak. It must’ve been leaking onto the motor which went faulty. Please correct me if I’m wrong in my assumption; once repaired, I will update the topic just for future reference.
