Mercedes white foam in coolant tank
Old Oct 23, 2022 | 03:27 PM
Anonimvv's Avatar
Mercedes w204 C250 2012
Unhappy Mercedes white foam in coolant tank
Hello. Yesterday I got low coolant warning. I bought new antifreeze from dealer then when I open coolant tank cap I saw black foam inside it but its actually white foam. How can I fix it? is it serious problem? Antifreeze color not changed. Oil level was ok. I had oil leak from oil filter housing and I replaced 7 month ago. Is any suggestion about that?
LO
have Mercedes w204 C250 2012 M271.860 turbo engine.
Old Oct 24, 2022 | 07:16 AM
95_993's Avatar
G63
Looks like a failed head gasket
Old Oct 24, 2022 | 07:32 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
Creamy brown oily foam on finger tip when tested ? Leave reservoir cap off and have a person rev motor to 2K rpms for a minute...may see bubbles in reservoir tank if HG leaking. Antifreeze smell at exhaust pipe tip ? No other source of coolant leak noticed ?...could possibly be residual oil from oil filter/ cooler housing cross contamination if you are lucky. Mileage ?
Old Oct 24, 2022 | 01:46 PM
Anonimvv's Avatar
Yes its creamy white foam when I clear with my finger. but antifreeze color not changed. there not any source of coolant leak. I made 161.000 km. I will check my antifreeze tomorrow what is smells like.
