Signal Acquisition and Actuation Module (SAM) Failure - Brake Lights Turning on autom
Old Nov 27, 2022 | 01:24 AM
pskrishnan's Avatar
Mercedes C220 CDI
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-unhide:no;
mso-style-qformates;
mso-style-parent:"";
margin:0cm;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Calibri",sans-serif;
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:Calibri;
mso-fareast-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;
mso-fareast-language:EN-US;}
p.MsoListParagraph, li.MsoListParagraph, div.MsoListParagraph
{mso-style-priority:34;
margin-top:0cm;
margin-right:0cm;
margin-bottom:0cm;
margin-left:36.0pt;
mso-add-space:auto;
font-size:12.0pt;
p.MsoListParagraphCxSpFirst, li.MsoListParagraphCxSpFirst, div.MsoListParagraphCxSpFirst
mso-style-type:export-only;
margin-top:0cm;
margin-right:0cm;
margin-bottom:0cm;
margin-left:36.0pt;
mso-add-space:auto;
font-size:12.0pt;
p.MsoListParagraphCxSpMiddle, li.MsoListParagraphCxSpMiddle, div.MsoListParagraphCxSpMiddle
margin-top:0cm;
margin-right:0cm;
margin-bottom:0cm;
margin-left:36.0pt;
mso-add-space:auto;
font-size:12.0pt;
p.MsoListParagraphCxSpLast, li.MsoListParagraphCxSpLast, div.MsoListParagraphCxSpLast
margin-top:0cm;
margin-right:0cm;
margin-bottom:0cm;
margin-left:36.0pt;
mso-add-space:auto;
font-size:12.0pt;
.MsoChpDefault
{mso-style-type:export-only;
mso-default-propses;
@page WordSection1
{size:595.3pt 841.9pt;
margin:72.0pt 72.0pt 72.0pt 72.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.WordSection1
{page:WordSection1;}
/* List Definitions */
@list l0
{mso-list-id:1136020953;
mso-list-type:hybrid;
mso-list-template-ids:-667926454 134807567 134807577 134807579 134807567 134807577 134807579 134807567 134807577 134807579;}
@list l0:level1
{mso-level-tab-stop:none;
mso-level-number-position:left;
text-indent:-18.0pt;}
@list l0:level2
{mso-level-number-format:alpha-lower;
@list l0:level3
{mso-level-number-format:roman-lower;
mso-level-number-position:right;
text-indent:-9.0pt;}
@list l0:level4
@list l0:level5
@list l0:level6
@list l0:level7
@list l0:level8
@list l0:level9
-->I own a C-Class W204 Mercedes Benz C Class C250 – W204 2011 December model. The part number is 2049005501151106150844(0). The Rear Signal Acquisition and Actuation Module (SAM) in my vehicle is showing an error and this results in the brake lights turning on automatically once in a few days. The brake lights turning on is more frequent after I complete a drive and the brake lights turns on after 6-7 hours after the completion of the drive. When the brake lights are turned on automatically, I start the ignition and pump the brakes 2-3 times and when I turn off the ignition the brake lights gets turned off and doesn’t come on for a few days if I do not drive the vehicle.
All the other functions of the rear SAM are working very well. We have removed the SAM, physically inspected it, there is no corrosion nor broken wires. The board is in very good condition and the only solution as per the technician seems to be the replacement of the SAM. I am attaching a screenshot of the error code (There is also an error relating to the actuators, please ignore it as this has been fixed)
I have the following queries relating to SAM that I would appreciate feedback from experts in this forum
1. Is rear SAM for Mercedes Benz chassis specific or would any W204 SAM fit a W204 model
2. Is there any way the SAM can be repaired / fixed
Look forward to views from experts if this error can be resolved. Shall appreciate your advice
Krishnan PS
Chennai, India
