Rear brake caliper bracket mount
2009 mercedes c300 4matic (W204)
There’s always Kroil, S’OK, and Marvel Mystery Oil penetrants to try. They’re all mostly the same but a little different.
Since the PBBlaster has had overnight to penetrate, try it again.
Tapping with hammer? Those 18mm bracket bolts can be impact wrench tight. If your 18mm wrench has a 6 point box, put a cheater pipe on it, hold as much force on it as you can with one hand and hit the bracket HARD with a big mechanic’s hammer. I keep a 4 pound maul for things like this.
It’s only a bolt. It will come out. Good luck.
