M271 Camshaft Adjuster Magnet Issue?
Oil could travel through the cable harness into the engine control unit causing serious damage to the ECU.
https://mbworld.org/forums/c-class-w...onnectors.html
https://www.slkworld.com/threads/cam...-cable.573555/
There are "Oil stop cables" which prevent this.
https://www.pressebox.com/pressrelea.../boxid/1040671
https://www.ebay.ie/itm/184939743944...YAAOSw7zxg7UFH
In Germany every Mercedes dealership knows this issue and will install those cables upon request.
Does anyone happen to be familiar with the part number for the harness extension on M271 EVO engines? I see plenty of discussion for the supercharged M271 variants, but none for the turbocharged versions. The camshaft adjuster magnets have different part numbers between the M271 variants, which makes me believe that the wire harness extensions are not applicable to both part numbers.
M271 EVO camshaft adjuster magnet: 271-156-00-90
M271 Kompressor camshaft adjuster magnet: 271-051-01-77
