W204 C250 CGI: Fail Start due to multiple Fault code
I couldnt find similar fault codes on websearch; Recently the Car had issues with ABS Control Module, it was replaced with a used ABS pumb, as of now we have replaced them with module, but the guy who was doing calibrations somehow the process wasn't successful, the car returned a total of 20 faults with 16 faults in a engine, So we replaced with another one, another person managed to successful do coding and calibration, but I still have six fault code, that wont go away, they have checked all CAN Connections, they couldn't find fault connection, they later suggested we replace ECU (Car Computer), I think its too extreme,
Fault list
1. U012800- Communication with Electric parking brake has malfunction-(Current and Stored)
2.P059800-Coolant thermostat has a short circuit to ground (Current and Stored)
3.P200A02: The charge movement flap (Cylinder 1 bank) has malfunction there is general signal fault (Stored)
4.P200A62-the charge movemnt flap (Cylinder bank 1). The signal comparison is fault.
5.P061451-Control unit transmission and combustion engine are not compatible: the component is not programmed.
any1 with any idea where to look,
battery has been replaced
Fault list
What is strange is that the car ran for a while and stopped working when the battery was replaced. Disconnecting and replacing the batter could have reset some things. Does your car have the automatic engine stop/start feature when it comes to a stop?
But, your car seems all messed up electronically. Changing the battery without knowing what you are doing could have messed stuff up. Sounds like a trip to the dealer is in order.
I have changed ECM (Engine Control), the car runs smoothly, surprisingly all faults I had before of knock sensor, ignition coil faults and TCM are gone, the car is brand, new,
