M271 EVO Startup Rattle
Does anyone have an idea of when I could be expecting a light to appear on the dash? I am intending on taking it to the dealer for a warranty repair, but I am certain that they'll require a CEL before performing the service.
It takes around 2 weeks of 2 starts per day before the CEL comes on. Probably less if the car is started many times a day. To set the CEL, the ECU needs to see the cam timing error 3 times in a row uninterrupted. Note that it will turn the CEL off again if it sees normal cam timing 3 times in a row, so the CEL may be intermittent at first.
You have a 2013. The extended warranty is 10 years from the original sale date of the car. Others have found Mercedes to be inflexible on the warranty expiration date. If your car was originally sold before March 2013, you may want to go to an independent shop or prepare to do it yourself.
