HID Hylux driver's side headlight stopped working
Hey All, my driver's side HID setup randomly stopped working after installing 3 months ago. I've confirmed that the ballast is good and I replaced the bulb. I get ~11v on the headlight harness, and a regular H7 bulb works on it. For some odd reason, just the driver's side HID setup no longer works. What are some additional troubleshooting steps I can take?
The Hylux ballast no longer makes a hissing noise when starting up, it doesn't warm up, and zero response from the device. Any thoughts?
Solved. Combination of errors: polarity mattered for the headlight harness and the ignition needed to be turned on since voltage dropped below the optimal level for the headlights to function on the battery alone.
pierrejoliat (11-15-2023)
