ESC Inoperative
Old Mar 25, 2023 | 06:12 PM
Tan1987's Avatar
W204 C300 4MATIC 2011
ESC Inoperative
I had problems with esc inoperative on my C300 4MATIC. And it stays on all the time .
Even Cruise controll is inoperative .
Does anybody has problems and how can i fix it ?
Thanx in advance
Old Mar 25, 2023 | 08:54 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Scan for codes. When traction control is faulty, it will not allow cruise control to engage.
Old Mar 25, 2023 | 09:15 PM
Tan1987's Avatar
Actually traction control is the problem but it can not be cleared as fault
Old Mar 25, 2023 | 09:41 PM
Odd Piggy's Avatar
Yes, I understand. But ESC and ESP errors also usually disable the cruise control as a safety measure. If you have trouble codes then they should help indicate the failing component. The yaw rate sensor and the steering angle sensor can bee sources of this error.
