Intake Air Temperature Sensor Location
I have a fault code P0097
'Intake Air Temperature Sensor 2 Circuit Low Bank 1' on my diesel C250 2010 Manual, I have a new part but don't know where the sensor is located, I am assuming I need to remove the ECU and get under to the airbox?
Typically, the fault occurred at the worst possible moment, just as we were leaving the UK to drive across France! Luckily the car kept going, it was a nail-biting trip, the dpf has become sooted up as a result. Now back in the UK I need to sort it out.
I've trawled the web and can't find what IU need to know, so if anyone can point me in the right direction to save me dismantling anything unnecessary, and disturbing other things that may raise other issues, that would be great.
Many thanks
Mark
If you have the part then just compare p/ns.
I think I will have to concede defeat and get it booked in, I'll update the thread with the outcome.
Thank you again, I really appreciate your input, have a good day and best of luck with yours.
I'm having the same problem error in my W204 220cdi. I've replaced MAF, MAP, outside temperature sensor...next i'm going to replace the air sensor in the crankcase breather...
DId you solved your problem?
If it helps folks, the Mercedes C250 CDI S204 intake air temperature sensor is located through the left hand front wheel arch, just take the wheel off and you can see it, takes 2 mins. I googled this for hours - nothing came up, my mechanic figured it out, so here it is to help future head-scratchers!
