Need help with a water leak inside the cabin.
w204 money pit
Hello. I have water coming into the passenger footwell and i have tried the usual methods at solving the problem. Blew the air through the hose, cleaned the crimped tips behind the fenders, yet the water is still coming in. And the water is coming in through an unusual spot compared to other cases i've seen online. Where the hell could this water be actually coming in through? Here's a link to a photo with highlighted highest point i can see from which the water is dripping from. Any idea why the water is coming in from that place exactly? The sunroof drains seem to work no problem, water goes down very quickly when testing, the water seem to exit at the correct place inside the fender. Windshield seems ok, though of course i'd like to exhaust every other option before i just hail marry and replace the windshield seal. P.s. The firewall drains seem to be ok as well. p.s.s The highest point of leak i can see is close the lowest point of the A pillar and to the right of the blower. Roof liner is completely dry, no signs of water around the A pillar itself. I have the A pillar cover removed and there's not a sign of water.
w204 money pit
https://i.gyazo.com/a83ee8e0d2870780...e5d796472f.jpg Link to the photo. For some reason i can't upload the photo to the post and when i post the link, it gets shortened so when you press on it, it fails to display the photo.... NICE.
To see the photo, press right mouse click on the link and select "open link in new tab" .
Did you ever get this resolved?
I am having the exact same issue with my 2014 C300.
First leak started with clogged sunroof drains.
Even after cleaning out the clogged drains water leaks into the driver footwell area where the parking foot brake is located.
Not a ton of leak but a slow leak after heavy rain.
