2008 C300 Drivers Window Control
Old May 13, 2023 | 04:55 PM
Red Raider's Avatar
2008 C300 4Matic Sport
Question 2008 C300 Drivers Window Control
The drivers window on my 2008 C300 will no longer go up with one touch. I have to hold the switch for the window to Rise and when I let go at the top, the window will lower about a quarter of an inch. What would it take to correct this issue?
Old May 13, 2023 | 08:49 PM
gamma300C's Avatar
2009 MB C300 Sport 4matic
Try the "reset" method.... Open the window and hold the window opening button for 10 secs after the window is fully open then close the window and hold the window closing button for 10 secs with it fully closed. That might fix it. There's the Disconnect the Battery . The driver's side Master switch (which has probably failed partially) replacement is easy and the part not too bad cost wise..OEM and Aftermarket on Amazon, eBay.
