238k 2011 C300?
238k 2011 C300?
For a used C300 Sport with the mileage but will pull maintenance records from a Benz dealer, would you guys entertain the idea or walk away? I need an awd car for the winters in Maine and I dig the design of the w204.
A lot of areas that others can chime in on as far as "need to be addressed" or "have they been addressed " ? I will only add that the transfer case on this 4Matic , if it hasn't had the 4 pinion bearings and front drive output "mini U-joint" gear/shaft assembly replaced ( and is still quiet, if working at all ) should receive an honored place in MB's Stuttgart Old Parts Home where it can live out it's few remaining days.
