Question for those who ever replaced a cracked exhaust clamp and sealing ring.
This is how my exhaust looked in the beginning prior to it being removed and the flange broken even more.
Here is how I got it back from Mercedes after they worked on it. I gave them a new sealing ring to install since i knew the old one was falling apart. Note mesh side of sealing ring is towards engine.
I ordered another new sealing ring to use to help with me figuring out the correct flange size. I dont feel like going under the car and removing the one thats installed. The exhaust leak isnt that bad so im in no real rush and want to do it right. I just noticed the ball joint parts i bought are in fact 201 stainless, i should have read the description better. Since I live right on the ocean, park my car literally 10 feet from the water I want 304 stainless at least. I may just use the parts to test fit everything and see where everything lines up. if my measurements are correct that pipe should slide over the old pipe and i can just install a clamp for now. i also ordered another flange that says it is 304 stainless, we shall see. I just dont think it is as thick as I would like, I may have to find someone to make what I want. I would like to have something bent up that I can send them to replicate if possible.
Description says it is 304 stainless.
So im just confused as to what the exhaust is actually made from, what type of stainless? A magnet sticks like crazy to the exhaust manifold and I thought that was stainless.
The 201 stainless pieces I bought are slightly magnetic at the bends only, on the straight section a magnet doesnt stick. I read this is a quality of 201 stainless that has been worked. I just dont want to install something that will rust in a year.
Again, thank you.
Last edited by geoffreybove; Nov 2, 2024 at 04:45 PM. Reason: I followed the recent post's instructions.....
I would just have the connection welded solid but im afraid if i even need to remove the cat will be a huge project.
How did you get that sealing ring out? What did you disconnect in order to get at it? I never seperated the exhaust before. The only thing i ever did was replace the clamps and I didnt have to remove anything, I just slipped them on over the pipes.
It seems the clamp itself is made of some type of stainless steel but the bolt and the cylindrical nuts are some type of magnetized metal. In my first post the bolt rusted away to nothing. Ill see what I can find at Lowes for stainless bolts and nuts.
I was thinking of welding the new flange in since i really just want a welder so this is a perfect excuse to get one. Learning to weld on my exhaust isnt the brightest idea but I cant see it being that hard. I'll be test fitting different adapters in the mean time until i figure what I want. I found a place online that will custom make any adapter I need out of 304 stainless.
I've been searching for what I need to weld the stainless steel and it seems in my situation mig weld in with stainless flux core wire. Using gas would cost me another $150+ if i went that route. The specs for that wire say to use mig DCEP. From looking around my house I dont have any separate 110v outlets so ill have to use my dryer outlet for 220v. i found one welder I want, may wait for Black Friday deals to see if i can get it even cheaper.
That parts is s funky metal! It's barely magnetic, very slippery. Very interesting.
Good luck!
I'm going to try just sliding the new piece on then putting a clamp on it, see how that holds up. From my measurements the new piece may be just a tiny bit too small, I was thinking I can make 2 or 3 slits down it so it can expand a little while pressing it on. I know nothing about exhaust pipes and the measurements were confusing me trying to order what I need, between the OD and ID and the material thickness. And finding out the part i received is only 201 stainless was a bummer. Like I said earlier I park my car 10 feet from the ocean. I think the salty air isnt very good nevermind the salt they put on the roads in winter. Im always washing my car so get the salt spray off it.
On a side note I came across a very interesting cause for a loud squeaking I was hearing. While driving, usually when backing out while turning the wheel i was hearing a loud squeak from what I thought was the front passenger strut. I had the car jacked up earlier both front wheels off the ground, I grabbed ahold of the spring and pushed it side to side and sure enough there was a loud squeak. Turns out the noise was coming from where the bottom of the plastic boot connects to the strut. I pushed the boot upwards so it wasnt snapped on to the strut and the noise went away. For now i just sprayed some silicone lubricant all over it. Drove around and the noise wasnt there any more.
I am also amazed at the amount of water that drips from these two joints, its alot.
I think i have a change of plans. I may just keep everything how it is and try to pack that joint, either a sealant or i was looking at stainless steel wool type material, the stuff used to pack resonators.
Im having trouble closing up the gap of the drivers side pipe though. I cant seem to get it any tighter, but not even sure if i can. I put a jack under everything to take the weight off, but cant seem to pull it together any more. I was thinking about using ratchet straps but then i wont be able to put the clamp on.
I dont know what toi do.
I tried experimenting with one of the flange pieces i bought but it came out pretty bad. Its harder to cut stainless steel with a hack saw by hand than I had anticipated. This piece isnt long enough for what i want anyways sowas just playing around. I'm thinking the next one i'll see if i can get a metal cutting blade for my chop saw.
I ordered a ball joint fitting that I think may work. Its 304 stainless, 2-1/2" OD pipe and I believe its 16 gauge so should be heavier and match the existing exhaust pipe. I'm hoping I can just cut the female section to size and slide it on, should be tight so no welding needed. i may even have to bang it on over the pipe.
https://www.ebay.com/itm/285734348965
My only issue now is the ID of the pipe is 60mm and the OD of the pipe on the car is 60.5mm, at least its what im getting using my cheap plastic calipers. Wonder if i can grease it up and hammer it on, or do I try and expand it a little?
The female end im getting 70mm ID at the mouth of the flange. I think the male piece will be a better fit, just have to trim it down.
With the sealing ring being 67mm on mine where it fits into the stock flange it looks like i'll have to trim the male section, should be left with 67mm ID for the sealing ring to fit.
I tried it on the female end of the ball flange kit and its not going to work, flange is too large and the sealing ring just falls into it and wont create a good seal. I did try searching for a larger sealing ring but im not finding anything with the correct ID and OD measurements. I realized they call the sealing ring a graphite gasket.
So next plan was to cut the male end of the kit, and I think its going to work well. I cut it with an angle grinder then cleaned it up with a hand file. Still have more to go. But it fits in, the gasket is contacting all around so it should be a good seal, and looks like the original 60mm clamp will work.
I tried the sealing ring in the end i had cut off of the male section and it fits great. I would love to use this piece, but I would have to weld it on to the pipe. Maybe i can bring it somewhere to have welded up and they can expand the pipe 0.5mm also. Either way it seems now I have two options.
I tried the SEC65 clamp and its a little loose.
Rough measurements of the sealing ring:
55mm ID:
Mesh part OD around 70mm:
Smooth inner part that fits in flange is 67mm OD:
